Dingy Davits and air floor boats
Sep 27, 2008
248
Hunter 41 Longport,NJ
Hi - moving to an air floor - need to have something lighter Most don;t have any provisions for dingy lift points like my old Aluminum bottom monster. Any recommendations ? Has anyone just put ona d-ring patch in the bow and drilled two holes in the plywood transom ?
danm1
Oct 5, 2013
233
Hunter 356 Mamaroneck, NY
Eyes on the transom are step one. Have read many added d-ring lift points inside tubes. I used towing rings this season with no problem although manufacturer warned against because of angle. They suggest strap all the way under hull in bow area. One idea I read about and may try next season is short strap with d-ring ends run under inflatable keel, coming up through air floor at hole for keel inflation. Would be simple if it works.
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
That's exactly what I did. The bow is very light and have not had a problem. I keep the 6hp on no problem.
Mar 26, 2011
4,010
Corsair F-24 MK I Deale, MD
The main thing with any removable floor inflaable is to suport the dinghy from underneath with tricing lines, every time. It is good practice anyway.
