I've gone through leaking PRV post and found nothing that relates to my problem.
We moved the boat to a different marina which required steaming 7 hours, which got the water heater water good and hot from the engine. Once at the new marina I hooked up shore water and the pressure relief valve began spewing. The Seaward water heater is 5 years old so I ordered and installed a new PRV. Realizing that the dock water is high pressure I also installed a 40 psi pressure reducer.
Imagine my disappointment when unheated water began flowing from the newly installed PRV once I hooked up shore water. I also tried just running the fresh water pump but it wouldn't stop running and leaked at one of the fittings. Where can enough pressure to open the PRV be coming from? What am I overlooking? Thanks
