Hi, I am planning on refreshing my yanmar 3GM3OF control panel. My boat is a 1987 Goman Express 35. I'll be purchasing part 128170-91010, Panel Housing and the gasket 128170-91020. I'll also be replacing the engine stop cable...everything else will be kept. However, the part of the control panel that really needs to be replaced in the plastic recessed housing and acrylic guard. There are cracks and not enough plastic left for the panel screws to grip, hence the washers.
Is this part specific to my boat manufacturer? Where can I order a replacement? If I can't, what are some ideas to create a new recessed housing for my new panel?
In case you are wondering, green pull to the left turns an engine compartment blower on/off...engine stop pull is hard see but is in-between the tach and fuel gauge. I understand the fuel gauge was installed aftermarket as the standard type b panel does not have one.
Thank you!
Thank you!
