Hi all—
I’m in the process of (maybe) adding a dedicated chart plotter/MFD, and could use some help figuring out the networking portion of the installation.
I’ve been using an iPad with Navionics, but have found that the iPad will not reliably read location data from my AIS transponder over WiFi. I’ve been relying on my iPhone instead, but it’s a bandaid, not a solution.
I’m interested installing a B&G Vulcan 9, but my current setup was installed before I owned the boat, and it’s a bit of a grab bag. I’m not quite sure of the best route forward for getting all the equipment to communicate in at least a rudimentary way.
Here’s what I have:
A) Is there a SeaTalk to NMEA 2000 cable that would connect my current SeaTalk backbone to the Vulcan, or is there a different/better way to get the new MFD connected?
B) I’m not 100% sure what protocol the NASA Marine transducers are using (I’m guessing NMEA 0183). It’s not essential that they feed to the new MFD, but it would be nice. Would that likely require a couple Antisense NGW-1 units (or similar), or does it make more sense to just replace those transducers with something newer at the next haul-out?
C) Am I grossly misunderstanding how this all works (it’s certainly possible!)?
Any help or recommendations before I go spend a bunch of money would be much appreciated.
Collin
Here’s what I have:
- NASA Clipper Depth and Log displays connected directly to their corresponding transponders (thru-hull depth, in-hull EM speed). Circa 2017. Not currently networked.
- Pelagic Standard Tiller Autopilot. Not currently networked.
- SeaTalk Backbone
- Raymarine ST60 Wind Transducer
- SiTex Class B AIS Transponder
- SH GX2200 VHF AIS/GPS
- Raymarine ST70+ MFD (To be replaced)
Collin
