For those whom have rewired your mast, what wire did you use (i.e. multiple 16/2, etc.)? I have the anchor light, which I will be replacing with a two-wire marine beam tri-color. I also have a steaming/deck light combo. What cable are you using for your VHF antenna? Mine has been replaced by a PO with what I think is RG-8. However, the connector fell off when I touched it and I don't think there is enough slack to make the connection when re-stepping. It looks like the wiring is run in a channel behind the mast track. Is that normal?
Also, I don't see a manufacturer marking on this mast. Which brand did Hunter use in 1986? My boom is a Kenyon.
Thanks much.
Thanks much.
