Hunter 386 Exhaust/Water hose
Sep 11, 2019
173
Hunter 386 Lake St. Clair
Hey guys...looking at changing out our water/exhaust hose when on the hard. Looks like it's original...2002. Reviewing the schematic, it shows a muffler. Does anyone know where this might be located? Hope it's not under the bed. Any thoughts on pulling this hose is appreciated.
Thanks,
Gary
JamesG161
Feb 14, 2014
8,111
Hunter 430 Waveland, MS
Typically the hose has a high loop before the exhaust outlet.
The Bed area is the low spot for muffler.:facepalm:
My hose, 1999, looks great.
Jim...
PS: Engine HP= 50
Jan 4, 2006
7,870
Exactly where your worst nightmare is picturing it :
This is for my 1999 H-310 but your 386 is likely in the same place.
1. Make sure no small children are within earshot. You're goin to develop a WHOLE new language when you do this :yikes:.
2. Use the old hose to pull a fish line if you have a convoluted install path.
3. Be sure to re-install the exit loop.
I had replaced mine after about 20 years as it had started to show tiny surface cracks so time to go.
One tough miserable job for sure but anyone with a Grade Four Reform School education is way over qualified for the job.
  • Ha
Likes: JamesG161
Sep 11, 2019
173
Ended up visiting the boat today and have the same as you. Doesn't look too bad, but I'll take the advice! Thanks,
