I have a Hunter 34 set up with a 276 ah #2 bank. This season we added 350 watts of solar which is connected only to the #2 bank. All battery wiring through to the DC panel and A-B Cold Machine has been replaced. Our #1 bank is a single 72 ah battery used for starting and our windlass.
The fridge / freezer unit works fine during the night hours. We recently started to hear a beep type sound in the early afternoon when the compressor attempts to start. It then cycles every 45 seconds, attempting to start, but fails. When this happens the solar is cranking 14v + into the batteries. As a note, we have also seen this happen, on occasion, when using the AC charger (pre solar installation).
Once the failure occurs, I have found certain things that will allow the A-B to start.
1. I can turn on blower, pumps that will put a load on the #2 bank, and the Cold Machine will start. However, the Cold Machine fails to start again on the next cycle.
2. If I switch to the #1 bank, the unit will start and will continue to run. It is a problem, since on one occasion I forgot to switch it back.
3. When I was using the AC charger prior to installing the solar, I could turn off the charger and it worked fine.
The symptoms indicate the problem is a voltage drop, but it only happens when an AC or solar charge is being applied to the #2 battery bank. I have been chasing this around for a while now. At this point I need some fresh eyes and ideas to explore.
