Rechargeable
Nov 23, 2018
32
Schock Harbor 25 Los Angeles
Any recommendations for a relatable small rechargeable pump for my dinghy? Thank you !
Feb 10, 2004
4,253
Hunter 40.5 Warwick, RI
@jviss has a good suggestion for a dinghy pump. I have one of those and I use it to top off my dinghy if needed during the season. It is much easier to use than the foot pumps in my opinion.
However in the spring when I first inflate for the season, I use my shop vac in blowing mode. It inflates very quickly and then I top off to the required pressure with the hand pump.
I don't know of any small electric pump that will inflate to the needed pressure. I think you would always need to top off with a hand pump.
Sep 24, 2018
4,805
Catalina 30 MKIII Chicago
Can you top it off with a high pressure, low volume pump? If so, Schumacher makes a unit with high and low pressure air pumps, inverter, jump starter (or trolling motor battery), light and probably a few other gadgets
