Purchased Northern 29 (built 1981) equiped with Universal Atomic Diesel Model 5411, cools with raw fresh water that flows to wet muffler (no radiator). Previous owner stated firm belief that exhaust tossing a cupful of water every 30 seconds or so was part of boat design. Doubtful, last year an investigation revealed inner lining of exhaust hose had collapsed and water bypass was fully blocked. Both deficiencies repaired plus replaced water pump with new improved pump, I think from Moyer Marine. However, repair guy couldn't get water to go up and over the highly-placed anti-siphon tubing so by-passed it with a much lower tubing lacking anti-siphon. This year, I discover water in the oil. Replaced contaminated oil. Re-attached anti-siphon tubing to rule out water being drawn in from wet exhaust. Started engine, then immediately opened raw water valve and monitored engine temperature and water discharge. Didn’t observe water discharging but exhaust didn’t sound dry. Engine temperature rose above spec parameters (70C VS 66C max) after 10 minutes, so shut off engine. Checked oil- milky look dead giveaway for water and confirmed approximately half a quart of water had been added to the fresh oil by unknown route during the 10 minutes. Refilled engine with fresh oil to spec. I've ordered in a new head gasket and shim from Discount Marine Source with plan to have a person competent at such things to take off the head to inspect the gasket and do a replacement. Is it reasonable to think a failed head gasket could introduce a half quart of water in ten minutes? If not the head gasket, what would you suggest? I'm also perplexed why a new improved water pump doesn't efficiently get water up and over the original design anti-siphon tubing which has been confirmed to not be blocked.
