AC Fridge overconsumption.
henri
Mar 11, 2021
23
Beneteau Oceanis Clipper 42 CC Antwerp
Hello,
On my hunter I have a fridge in AC with water cooling. This type of compressors usually takes usually a 100W. In my boat it takes close to 2000W (yes two thousand. What could be the reasons of such an overconsumption ?
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
Not questioning your numbers but at 12 volts that would be 166 amps using a 2/0 cable. You should be blowing fuses left and right. My compressor is wired to a 10 amp breaker using #12 wire.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I think there may be a language issue here. He says "fridge in AC with water cooling," but I can't tell if it's a 120V or 220V AC fridge, or maybe an air conditioner. He must be plugged in, or have a generator.
Likes: ggrizzard
henri
Mar 11, 2021
23
We are in 230Volts AC and I measured about during several minutes, before the fuses blew. Same measured when I use an inverter, it is around 90 amp in 12V
7,699
Alden 50 Sarasota, Florida
Hello,
That is normal.
my understanding is that you refer to the air conditioner here. If I am correct, it’s not possible for that to require only 100W.
a typical 16,000 BTU air conditioner requires up to 10 amps at 230v Or 2300 watts. Or at 12v, it is equivalent to over 200 amps. Again, over 2300 watts.
JamesG161
Feb 14, 2014
8,033
Hunter 430 Waveland, MS
You should clean out your AC water discharge line.
I sometimes use Crushed, Spa Chorine tabs in the inlet stainer to keep my lines clean.
Also your cooling water temperatures have effects too.
Jim...
Dec 25, 2000
6,055
Our boat has two 120VAC reverse cycle heat pumps; 16K BTU main cabin, 9K BTU aft cabin. Combined, they consume 12 AMPs of power, which includes the Little Giant sea water pump. That equates to 1,440 watts. Check for a good water flow out the through hull. Could be the compressor reaching end of life. Unclear whether it is the heat pump (air conditioner) or refrigerator.
henri
Mar 11, 2021
23
It is a fridge and freezer for the kitchen. Current is Alternating current (230V AC). Consumption is 1000W (and not 2000W as erroneously stated) . I had the same compressor on my other Hunter and consumption was one hundred watt not one thousand. What can it be wrong with my system, that would increase the consumption in such a way ?
Jan 4, 2006
7,682
What gauge or meter are you looking at to see the present 1,000 watt loading on the compressor. Are you reading the same output gauge or meter when you saw the 100 watt load ?
I can't see 100 watts running a compressor but 1000 watts does seem a little high.
I just stuck my nose inside our refrigerator and this is what I see for its draw :
115 volts X 3.5 amps = 403 watts for a 22 cubic foot freezer/refrigerator without a cooling water pump. Is there any way of checking the amperage draw on your cooling water pump alone ?
Dec 28, 2015
1,945
His is 220 volt so it would be 200 watts
Jan 4, 2006
7,682
Can't follow the math on that calculation.
My point in getting the amperage readings is : are these readings from a fixed panel mounted amp gauge or from a hand held ammeter ? Maybe one or the other has developed a problem with readout.
Dec 28, 2015
1,945
If the same unit was 220 volts, the amp rating would be 1/2 of what is on your label.
Jan 4, 2006
7,682
Yes the amperage would be half for his 220 V supply but the wattage would always be the same regardless of the supply voltage. Of course we can't put just any voltage into the same compressor but you get the idea. The work input to the compressor (measured in watts) will always be the same, regardless of the supplied voltage.
And that information along with $2.50 will get you a cup of coffee in most restaurants.
Sep 24, 2018
4,571
Catalina 30 MKIII Chicago
A partially clogged refrigerant line could cause the compressor to work harder. I've also seen compressor motors draw more current than usual when their at the end of their life. Shorted windings perhaps?
Some compressors also have an extra winding just for starting
Dec 28, 2015
1,945
Sorry, meant to say amps not watts in my previous.
