Hi All,
Hope your weekend went nicely.
I have a boat, it is a Dufour 34, 1975.
It is a simple boat for a simple guy like me.
It is Sloop Rig.
There is a wheel in the back which you can rotate, I can't remember which but let's say clockwise tightens the backstay.
I have a furling jib.
I sail the bay area, so usually morning is light, mid day is mid and later on in the slot it becomes a game of sail reduction to avoid stressing my crew
and making it enjoyable.
so
Is there a rule on sail reduction.
I heard one rule which is start from the bow, so Jib first ?
Another guy said it is the sail that is closest to the wind.
Let's say jib first,
This sounds great, but then i have a furled jib which does not have a nice shape
and a full main.
The second item.
Is there a rule to how much I furl the jib.
Do they both have to have the same "height" as the main ?
You can reference no reef, reef 1,reef 2
So every time I want to reduce sail, I should reduce both to keep the mast balanced ?
Third item. - You can reference the MAST item.
As the wind is growing stronger.
I assume the mast is being pulled more and more toward the bow of the sailboat ?
As the jib sail is further and further to the bow.
The more I reef, the more it pulls to the bow ?
The main also moves the center of effort closer to the mast
Am I correct and if so, do I need to spin the backstay adjuster to tighten the backstay ?
Last two items.
I was told as the wind moves along to pull the jib cars further aft.
I was told as the wind moves along to tighten the halyard on the main and pull harder on my outhauls.
I've found both of the above to add maybe single digit control, they were definitely not double digit control like reefing a main or furling a jib.
Are these like "micro" adjustments ?
It is Sloop Rig.
so
and a full main.
The second item.
Last two items.
