Both Portside and Starboard side windows have cracked. Is there somewhere I can get replacements?
Ah, a man who knows his way around a router.I made a cheap plywood template and then used a trace bit on a router to cut mine out from larger stock
Yep, if we believed in old wive's tales we would have.So, did you guys who made your own replacement acrylic lenses actually stress relieve them, to prevent or forestall crazing?
It's not an old wive's tale, it's well documented, scientifically, and has been know for over 50 years, and published by Rohm and Haas. I know from having made acrylic underwater camera housings.Yep, if we believed in old wive's tales we would have.
A. Acrylic sheet has changed in half a century so I have to doubt those findings.It's not an old wive's tale, it's well documented, scientifically, and has been know for over 50 years, and published by Rohm and Haas.
Care to share "what you know" that justifies all of the black magic requirements that you see on the net for working acrylic. Again, I emphasize that this does not include hot working acrylic.I know from having made acrylic underwater camera housings.
Only cast for mechanical properties and resistance to scratching.Any special acrylic i.e. cast
Only you know that. If only a pound or two are required to match the curvature, I think you can live with it. Install it properly with small screws which are removed after a few months and replaced with black 795.Did the replacement need bending to fit the bulkhead?
Whatever, I don't care, just thought I'd mention it.A. Acrylic sheet has changed in half a century so I have to doubt those findings.
B. Without posting a copy of the Rohm and Hass findings, just internet.
I highly recommend you touch base with this site’s store. Although there are only 2 listed in the link, it is likely they will get exactly what you need.Both Portside and Starboard side windows have cracked. Is there somewhere I can get replacements?
Since I worked near a Rohm and Haas plant in Louisville KY. I know their process for making Acrylic sheets.It's not an old wive's tale, it's well documented, scientifically, and has been know for over 50 years, and published by Rohm and Haas.
