I do the same with 2 boards of 5/8", shlacked and covered with sunbrellaWe got fed up messing with the three boards all the time so I cut a sheet of 1/4" plastic (not sure what type it is) to fit the opening. Now we can just take one thing in and out and it's lighter than the boards because it's thinner. We can still use the boards when they are needed.
Thinking of doing the same but have a couple of questions.I made my doors out of starboard. I have hooks so I can hold them open while sailing. Also have a hook so I can keep them closed.
Not a good idea.Have boards for the companion way but really think I want doors
Out.Thinking of doing the same but have a couple of questions.
Do the doors open in or out?
Did you use the track that the boards mount in? If so did you secure/screw into the track or surrounding fiberglass?
Would love to have them in the same track and be able to remove and use boards if applicable.
Thanks for the reply...
These doors were installed by the previous owner on my Hunter e36. I really like them. Combination lock works fine. Hinges are designed so doors can be lifted out easily and stowed when needed. Boards can then be placed in when required. Zarcor does recommend stowing them while sailing. The doors have aluminum slides to keep them open. They work okay but I use small plastic clamps to hold them tight.Prior owner installed Zarcor doors Companionway Doors by Zarcor provides style, comfort and convenience to the entryway of your sailboat
I do like them, particularly the ability to put in screen panels when cruising. I leave the solid panels in at the mooring to keep rain out. Certainly easier for rapid cabin entry or exit than hatch boards.
There are two negatives. 1. Whether by installation error or design, the built in lock mechanism doesn't line up well with the hatch, so I have to use extra eyes and a padlock. 2. Dangerous if open when sailing...they can catch lines and spear you with the top corners. I am always reminding people to shut them after going in or out of the cabin and sometimes even I forget.
Hello,I'm sorry, buy I'm still trying to figure out how to transfer pictures from the Linux machine to the Chrome Book, so no pics. Quite simply, if you live aboard or use the boat often, in a climate where it might rain somewhat often, boards are a real PITA. Put them in for a rain squall and nobody can come and go. Boards are something I wholeheartedly suggest if one is transiting the Southern Ocean, or sailing through a hurricane, but for everyday pleasure sailing, they suck!
Absolutely the very first project I did, after letting the fact that I just purchased a 53 foot ketch to single hand for the rest of my life, was to build a Starboard companionway door. It had to slide in the hatch board slots, and had to be released by unscrewing no more than 2 screws. It was just enough off center so it would automatically close when we were not underway. The total cost was around $300.00 and it was still going fine when we sold her 13 years later.
I build a door out of starboard which attaches to a frame that slides into the board slots. I use barrel bolts to lock the door to the frame and sliding hatch from the inside, and have a padlock that is on a tang attached to the sliding hatch from the inside, through a slit in the door, to lock the boat if I leave it. The door can be held open, or auto-close w/a bit of shock cord.Hello,
Do you have a recommendation for a Hunter 45 CC where our companion door is unable to lock
