Catalina 310 Lightning Protection
Fleet
Feb 8, 2021
27
Catalina 310 108 Lake Guntersville
Owners manual isn't definitive on whether we have a ground plate and if our mast is connected to the ground plate. I don't remember seeing anything that I thought might resemble a ground plate on the bottom. Does any 310 owner know if our mast (boat) is designed to take a lightning strike?
I don’t know the 310 specifically but it’s pretty likely the lightning protection system goes to the keel. I think most bolt on keel boats are set up that way.
7,751
Alden 50 Sarasota, Florida
Dynaplates aren’t standard equipment on Catalinas. If one exists on your hull, it would be obvious.
Assuming you have a deck stepped mast, you should look at its base to see if there is a #6 or larger wire extending to a keel bolt (Or dynaplate). Or conversely look at the keel bolts to see if there is a wire extending up from one.
Aug 29, 2016
138
Catalina 2004 310 (Hull #250) BC
Additional to the above comments in a lightning system, is possibly, a dissipator.
SJN
May 30, 2021
43
Catalina C310 Seattle
Hello. The Factory manual for my boat, hull 260 provides a great deal of information about lighting protection. That said, factory installation of lightening protection was not a standard or factory listed option when my boat was built.
Fleet
Feb 8, 2021
27
Thanks all. I'm going to inspect my keel bolts and mast step for any kind of ground wiring.
