Getting wires in.
Apr 26, 2021
9
Hunter 306 CVDM
On my Hunter 306 2003, I am adding 2 solar panels on my back bimini. I want the wires to be as invisible as possible. What would be the best way to go in the boat?
5,308
Pearson 37 Lusby MD
I don't have a Hunter, but my wires are attached to the bimini frame, then to the pushpit and into a clamshell on the stern.
Mar 27, 2021
177
Hunter 306 Lake Pepin
The cockpit speakers are wired in through the bimini arch and are quite invisible. I'd follow that same path.
Jan 4, 2006
7,466
As per @jdrutten , drill holes in the SS arch and feed them through the SS tubing. Use grommets around the wire to avoid cutting them and then seal with your favorite sealant. Much of my outdoor wiring goes through the 1" dia. hand rails.
Likes: MFD
Jun 1, 2009
1,869
Hunter 49 toronto
On that topic…
When you put wiring through stainless tubing, the grommets you want to (must use) are Heyco snap in bushings . These are nylon headed bushings which are available in every size under the sun in Back & white
Do not use rubber grommets. The sharp stainless will cut through them.
Drilling good round holes in stainless tubing is a little challenging. If you don’t do it the right way, they end up oval- shaped with lots of burrs.
Here are some pointers
Xmas tree bits are fabulous, as they open up a pilot hole to larger sizes keeping a perfect circle. You will need a short version that gets up to your diameter in few steps, as you’ll run out of depth
If you want to use regular drill bits, use tungsten carbide absolutely
Then there is a serious “trick”
To drill round holes in sheet steel, etc, put a piece of rag on the hole when you drill. In other words, you are drilling through the rag.
Do not ask me why this works. It just does.
And use cutting fluid. NOT wd forty
Good luck
Likes: jdrutten
