ThIs engine starts up beautifully and runs like a sewing machine. However she heats up after about 15 minutes. There is, what appears to be, sufficient water flow through the exhaust. However, she heats up into the red after 15 ,minutes. I had tbought the sea strainer was plugged. Tried to service that and could not get the wing nuts off. Corroded on solid. I bypassed the sea strainer with a longer cooling hose from the raw water inlet to the engine. Still overheats. We then had a diver check the raw water inlet from the outside and found some contamination. That was cleaned and it improved the water flow a bit. But we are still over heating.
Does anyone have any thoughts on what else to check.
This boat ran fine for4 hours and then sat for 5 months. The previous owner did not bother to ever clean the bottom. I have had it done on a regular basis.
