New Alternator Regulator?
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I just occurred to me- When you test the alternator with a resistor connected to the field connection, test it with a resistor connection to 12V as I suggested before and also to ground. Some alternators supply 12V internally and the external regulator grounds the field. Others have the field grounded internally and the external regulator supplies 12V to the field connection. I don't know which type you have so you need to test both ways so you don't get a false result.
Is that P-type vs. N-type?
jviss
Feb 5, 2004
7,090
Finally got back to it. Blown 10A fuse for the field supply. Replaced it, immediately blows again. Field winding 5.6 Ohms, which is normal. Energized it and it magnetizes. Strongly suspect bad regulator output module, probably the field output MOSFET blown and shorted to 12V. IR540 - $1.49 at Digikey.
jviss
Feb 5, 2004
7,090
Would like a replacement regulator on hand in case I'm wrong!
jviss
Feb 5, 2004
7,090
The state of the art regulator is a Wakespeed. It uses the actually amperage generated to regulate the alternator, not the voltage output as all other regulators do.
Just circling back on this, whew! that's an expensive regulator! Like, almost $600 plus $120 for the wiring harness. Wow.
jviss
Feb 5, 2004
7,090
@Stu Jackson
Your Link 2000 R was the regulator controller, and we have no way to know why you had that separate Heart regulator in addition to the Link 2000R.
I am pretty sure what's going on here is that Xantrex distributed the voltage regulator functions across the Link 2000-R and the "Ideal Regulator Output Module."
But you can continue to use the Link as "just" a Link 2000 (battery monitor and I/C I/O) and keep the Freedom, too.
Yes, thanks, I think that is so.
11,760
i have a bunch of brand new MC-618’s. full warranty $200.00 each
jviss
Feb 5, 2004
7,090
Oh, wow, that's a great price. Is that with the wiring harness? Do you have the battery and alternator temp sensors, too?
11,760
Yes the are Mc618H (H=harness)and I have piles of temp sensors too..These are way below distributor cost..
jviss
Feb 5, 2004
7,090
That's excellent. I will contact you if the need comes. I already have a couple of alternatives in the works, including just replacing the MOSFET in the module I have. It might be worth getting the 618 setup even as just a backup!
Nov 21, 2012
807
Momentarily Boatless Port Ludlow, WA
I think you've got it backwards. At that price the obsolete boat anchor you're trying to restore should be the backup.
jviss
Feb 5, 2004
7,090
I hear you, but I would actually lose some functionality, I think, going to the more modern one while not replacing the entire system. As it is, the Link 2000-R panel and display controls and programs the regulator, so no magnetic screwdriver needed! But, we will see.
jviss
Feb 5, 2004
7,090
Big shout out to @Scott T-Bird , who sent me a Balmar MC614 regulator! Wow. Very generous. So, regardless, I will be charging and back in business before the weekend! Thanks Scott!
jviss
Feb 5, 2004
7,090
Digi-Key rocks! Ordered MOSFETs Sunday night, they will arrive today, via USPS first class mail, cheapest shipping alternative: $4.95. So, about $10 for 3 MOSFETs. Time to fire up the soldering station - I have a pretty good soldering/desoldering rig, with vacuum desoldering, etc.
The plan is to remove the old one and test it, just to confirm; there's a technique for testing MOSFETs with a DMM. Then install a new one. Won't take long.
Meanwhile, I have the MC-614 that @Scott T-Bird so generously sent me. That could be a quick swap, as both use the standard Ford plug, and that's all the wires you really need for this. However, if I go with the 614 long term I will locate it outside the engine compartment, which will require re-routing the harness. The existing harness is still full-length, it was just bundled-up with cable ties, so not so tough.
11,760
Hi, I'd like to buy one of those 618s and the temp probes, too. Thanks.
I have no ability to ship unless I can get my daughter to do it.. They are 4 minutes from Portland, ME..
