Hi All,
I hope your day is going well.
I need a sanity check.
I have the companionway step below I took out.
It had some insulation for sound in the back, it was torn and falling apart.
I removed it completely by scraping and hand gun, then used my wood plane to shave it to raw wood.
So I have raw wood.
I wanted to attach sound proofing as my engine is a noisy but cool MD2B 1974,
I got Soundown Sound-Stop Foam Panel with 1lb Barrier Layer Foam 1.5".
I thought for some reason it had a tape which you remove and glue but it does not.
So
1. I need to buy either glue or double sided tape. What do you recommend ?
2. I need to buy Pin Fasteners, attach them to the wood using glue epoxy.
3. I put the glue on. Any glue brand you recommend ?
4. I apply the Foam panel.
5. I put the washer and domed cap on the pin fasteners.
6. It says to put side adhesive , so I assume you do this before you apply the material ?
Anything I am missing ?
or any better idea?
So I have raw wood.
So
or any better idea?
