Spreader bird deterrent lines…..
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Hello all,
so I have seen many boats with fishing lines hung like a web over the spreaders… starting where spreader meets mast then going to the stay a few times to make a fan like deterrent. How do people attach these lines and what are the best to use. I assume a heavy fishing line is best.
thanks
s/v Souleil
Hunter Catalina 400 PORT JEFERSON, NY
A more permanent method
I have tried string, cable ties but nothing lasted years. I finally came up with a solution. I secured a piece of teak 1/2" thick by 2" wide and long enough to go from the end of the spreader at the stay and about 12" short of the mast. With a nail gun I shot SS 2" finishing nails so the heads were flush about 1" o.c. in a zig zag pattern. I attached the assembly to the spreader using 14 guage Romex, only the white wire, to the spreader and twisted the ends where they met on the underside of the spreader. I have used this method for over ten years and have never had a bird perch on the spikes for more than a second.
NYSail
Jan 6, 2006
3,187
Home made spikes….. thanks for the input!
May 1, 2011
5,592
Pearson 37 Lusby MD
Do you have any photos you can share?
Oct 1, 2007
1,865
Hello all,
thanks
s/v Souleil
Google"Bird B Gone". I used these on my spreaders for 15 years.It is a permanent solution.
dmax
Jul 29, 2018
1,362
Telstar 28 Buzzards Bay
I inserted screws on either side of the mast about 4" above the spreader and then ran a pieces of SS wire from the screw(s) to the end of the spreader (so the SS wire ran above the spreader arm) - never another bird.
