Im not sure how different yours is to the H49 I have. But it seems similar. I took a long time to get mine even nearly right and many so-called riggers came. This area is my weakest on boats but what I have learnt is yes unless your very confident its worth getting someone in. Also most riggers have no idea about a B&R Fractional rigg, so generally unless they know this particular type of rig, you will waste your money. Probably more than 50% of boats these days have there rake wrong, simply because they tend to load the boat up with all sorts of shit in the transom so the stern drops and the rake becomes out unless you counter this by adjustments to the rig. In my case solar pannels davits etc dropped the stern creating this problem. Adjusting the forestay is not that difficult. The Seldon manual will tell you the sag ( I think if memory serves mine is 13" max). Hard to measure this of course. I ran a dyneme line down beside the forestay with a 10" cable tie sticking out horizontal halfway down. If there is to much sag, then it implies the cap shrouds and forestay are out of balance ie too lose, so cranking up the forestay turnbuckle is easy and if you follow the instructions other than upsetting the rake you are unlikely to cause any negative issues, assuming you dont try to take the sag all the way out when its loaded, and make sure you don't invert the prebend. I would not touch the diagonals unless your very confident. The Cap's and forestay are not a problem. But always count turns, so you can put it back, and what you do to port you should also do to starboard assuming the mast was vertical and straight. The tensioning tool (Loose) is of no use on H49 it doesn't go big enough. Selden will tell you to use the stretch measurement to guage the tension. There is a formular for x wire gauge stretch per meter. A laser pointer or measuring tool and a lot of patience you can do it. My rig also had to much prebend, and it was in that state too long and while better than it was, it's still not right. Hope that helps
