Working on rewiring the mast and came up with a couple things. I will post (a rant?) in a separate post about the other item. I have a wiring diagram I think I got from someone in this forum, and am trying to straighten out some wiring "oddities." The wire (white/red) to the anchor light is wired to the switch/fuse panel, but there is a couple of spade splitters (1 female to 2 mail spade terminals). The panel has a Dymo label over it saying "inst. power" (see pic). Don't want to remove it because I don't have a Dymo if I want to replace it. So a couple questions. First, does anyone know what the actual label (beneath the Dymo tape) says? And shouldn't the anchor light be switched on/off independent of anything else?
Answers to both of these will help me figure out the best correction w/o further adding to abnormalities.
