Dinghy Power
Dec 11, 2015
311
Hunter 25 Plymouth
Need advice, I just purchased a used inflatable dinghy w/o propulsion (West Marine RU 260). I need to tow my 28’ sailboat to the mooring (transmission problems). How big/HP can I use on this dinghy? Your wisdom appreciated.
From the specs page... 10 hp
  • Manufacturer's number : NZ11450C
  • Dimension : 2,60m (8,5')
  • More Information : 5 years Warranty
  • Model : Cadet RIB 260
  • Floor type : Coque rigide
  • Engine : 10 hp max
  • Overall length : 2.60 m - 8’6”
  • Inside length : 1.72 m - 5’8”
  • Overall width : 1.56 m - 5’1”
  • Inside width : 70 cm - 1'5"
  • Hull : Fiberglass
  • Total trailer weight : 52 kg - 115 lb
  • Tubing : 43 cm / 17"
  • Tubing color : White grey
  • Number of passengers : 3
  • Maximum authorized payload (Cat C) (Kg/lb) : 400 kg - 882 lb
  • Airtight compartments : 3
  • Outboard Shaft Data : Court
  • Length : 2.6 m
  • Fabric : PVC-Strongan
Likes: ggrizzard
I guess I would go with transom weight since there seems to be some abiguity on HP.
Dec 2, 2003
766
Hunter 260 winnipeg, Manitoba
I think the ambiguity is the model number - one is a rib-260 (10hp or 6.5?). The other is a ru-260 which is 4. Roll up vs rib.
Likes: rgranger
Johnb
Hunter 37-cutter Richmond CA
Sorry, this is barely believable that people could mix up RIB and RU and then blithely state about 2.5 times more H.P. than is allowed.
And others give likes...
Oct 26, 2008
6,370
Catalina 320 Barnegat, NJ
Well, he did say that he sometimes wonders whatever happens to all those people who ask him for directions! :biggrin: (I know he can take a ribbing!)
Likes: rgranger
Jul 27, 2011
5,144
Bavaria 38E Alamitos Bay
Hip-tow would be better if in restricted area, such as in the marina, where you might need to maneuver the sailboat into its slip. If out in the open going some distance with no “sharp” turnings a long tow would be the better.
311
Hunter 25 Plymouth
Based on the capacity plate you can have a max 4hp motor on that dinghy.
Sometimes easier to manage tied alongside than to handle as a tow.
Thank you, yes agree with side tow, the harbormaster does the same and I did see the plate and HP but was a bit unsure of the weight requirements - thank you!
