I'm finally finishing my instrument panel modifications and I bought a Blue Sea Systems terminal block for 10 circuits. The terminal block connects the circuits for power leads, grounds, and sensor wires for the keyed switch, push button switch, warning lights and instrument senders, etc. The original terminal block was the kind that you insert a bare wire end into a slot and turn screws down on the wire to capture the wires. I thought it might be a good idea to use ring terminals so I mindlessly bought a 20 amp - 10 circuit block for ring connectors. Two things came to mind:
1. Is a 20 amp block the right size? The starter motor wire is 10 awg and I wasn't thinking about that load (I was thinking about all the much smaller loads). I don't really understand what current needs to pass through that wire. Amperage chart seems to indicate that 10 awg is good up to 30 amps. I could have chosen a 30 amp terminal block or a 65 amp terminal block. I'm thinking I should get at least the 30 amp block and maybe the 65 amp block.
2. There is no cover for these blocks. The ring connectors are pretty well protected by the dividers, but ... you never know about all those wires inside a cramped space ... there are both positive and negative leads inside there ... I suppose I could simply cover the top of the block with tape. I don't really like the original block that relies on screw pressure to capture the wires, but the connections are better protected. Thoughts?
