My oil pressure alarm went off and I instantly shut the engine off.
After anchoring and subsequent rescue by Seatow, I started the ugly cleanup and diagnosis.
- I changed the oil and filter last fall before haul-out, exactly the same way that as I have done for 5 years
- The area around the oil filter appears high and dry. No sign of leaking at the filter
- There is break were a flexible tube meets rigid metal at what I believe is the oil pressure sender. I expected that monitoring to be all
signal wiring, but noticed it to be very oily. Has anyone ever heard of a pressure transducer failing and oil spewing out the housing?
- Finally I found a pretty big bolt in the engine bilge. It is 24mm long and 10mm in diameter. It looks similar to the bolts used to
hold the alternator's tensioning bar. (13 or 14mm socket)
I'm on the Hudson River, so thankfully do have access to mechanics and parts.
Any similar experience and fix would be most appreciated.
