Glue to attach handle to hatch
Jun 20, 2021
165
Beneteau 343 Fort Lauderdale
what would be the best glue to reattach the handle to the hatch? JD Weld epoxy lasted for a few days and then fell off on a calm morning.
Can you buy a handle that bolts through the plexiglass? Lewmar hatches use through screwed handles to secure the hatch.
Jun 21, 2004
2,874
Beneteau 343 Slidell, LA
I had handles on both of the forward overhead Lewmar hatches de-bond within the past three years. Epoxy won’t work; have to use Plexus MA 310. (Methyl methacrylate chemistry). Same stuff that Lewmar used. Sand the handle surface to remove old glue & use a sharp chisel to remove old glue from lens & sand. Clean surfaces with alcohol. Mask the lens with painters tape. Check the handle position on adjacent hatch. I clamped for 24 hours, after gluing, before use. First repair has held up for over three years. You can also purchase new screw retained handles & gaskets from Hatch-masters
Jun 21, 2004
2,874
I stand corrected, the first handle that I reglued with Plexus MA310 lasted 6 1/2 years; debonded a few days ago. I am checking out the conversion to screw retained handles (Lewmar # 360255990) for the size 20 low profile hatches. Saw a video on You Tube on the conversion; have to admit I am a bit nervous about drilling a hole thru acrylic with a step drill:yikes:! If you get in a jam and need a quick repair, the Plexus method is pretty good.
Jan 18, 2024
3
Hunter 456 Passage Channel Islands Harbor
How long did the unused Plexus MA310 last? Thanks. I realized I've got hinges, these latches and the three side clips on many many of my portlights. The first one popped the other day, so it's not just a project, it's probably the first of many.
