That is a Portal and not considered a window.Have a window with a gasket that is coming undone in one corner
Thats a good idea with the hair dryer, Thanks! Its such a strange design.... the slot where the gasket is suppose to slip in is in a strange place.... mid gasket. I'll try and get a better picture but in the second picture you can see the slot. The gasket has a small lip mid gasket that goes inside.You might try warming it (agressively) with a hair dryer. Once it is soft, you may be able to pry it in with the flat blade of a screw driver.
A "portal?" I have never heard that term in the context of boats. Do you have a reference?That is a Portal and not considered a window.
A Portal is "Water Tight" like your hull.
Is the Portal leaking?
Jim...
It makes a difference, if you have to order a replacement.Sorry for the lack of proper verbiage
The word "portal" does not appear in that document.It makes a difference, if you have to order a replacement.
This may help you.
I think you have to push it in with a plastic roller tool but be sure not to puncture the gasket. A screwdriver is discouraged if it is sharp enough to damage the gasket. I'd guess that if the gasket has come out, it is damaged and can't be re-installed. I just bought a new gasket. Good luck! I have one to replace, too.Hello all,
Have a window with a gasket that is coming undone in one corner. Picture does not do it justice but hoping someone has experience with these windows. The gasket piece has to be inserted into a channel…… can’t figure it out. A special tool?
thanks
It is probably one of those autocorrect issues. The word is porthole (PORT-HOLE)...The word "portal" does not appear in that document.
It's funny that when correcting someone else's terminology, the correction is incorrect.It is probably one of those autocorrect issues. The word is porthole (PORT-HOLE)...
Autocorrect... it can be your worst enema.It's funny that when correcting someone else's terminology, the correction is incorrect.![]()
Lighten up, Francis. Where's your sense of humor?Well it is a Portal or PortLight.
Window it is NOT.
Get a grip @jviss and stop correcting peoples stuff.
Jim...
You may be right….. these are original from 2005……. Another job, but thank goodness this porthole is in the cockpit under canvas. Gives me time….I think you have to push it in with a plastic roller tool but be sure not to puncture the gasket. A screwdriver is discouraged if it is sharp enough to damage the gasket. I'd guess that if the gasket has come out, it is damaged and can't be re-installed. I just bought a new gasket. Good luck! I have one to replace, too.
Good pointI think you have to push it in with a plastic roller tool but be sure not to puncture the gasket. A screwdriver is discouraged if it is sharp enough to damage the gasket. I'd guess that if the gasket has come out, it is damaged and can't be re-installed. I just bought a new gasket. Good luck! I have one to replace, too.
I had the same issues and you can fix this too. Go to the auto parts store and ask for 1/8 inch silicone vacuum hose, about 4 -6 feet cost you about $5-6 dollars. Cut to size with about 1/8 inch extra to fit the channel. add a little RTV sealant to provide a seal between the two ends. and you're done. I did this to all my portlights about five years ago and not a single drip or leak since. I'll try to take a pic of the port and a picture of the vacuum hose later today.Hello all,
thanks
