Problems with early 310s
Apr 17, 2021
7
Catalina 310 Chicago
I thought I remembered reading here that there were some design flaws in the first couple of years of the 310 that got ironed out in later hulls. But I've searched the forum and can't find the thread.
Can anyone remind me what the issues were and in what year they were corrected?
Thanks!
Sep 29, 2008
1,981
Catalina 310 #185 Quantico
The things I can remember is they used
1. Crappy plastic damping plate
2. Crappy transmission
3. Heat exchanger with brazed on tabs to go onto the back of the engine
All of these were fairly easily repaired replaced. I am sure there are others, and these issues were not necessarily isolated to the 310's or Catalina.
Jan 4, 2006
7,870
Those qualities refer to the engine. Do you remember what the engine make was and the year ?
Sep 29, 2008
1,981
This is for the Universal (Kubota engine). I understand later models have Yanmars. The way I understand it works, is the sailboat builder will put out a quote for engines and buy 500 or some number at one time and use them until they need more and put out a bid for more. For 2002 to at least 2002 I understand Universal was the path with Hurth transmissions.
JRT
Feb 14, 2017
2,059
The standard engine is Universal for the 310, very few, hull #1, had a yanmar. We have 3 310s and a 320 in our Marina with so far no transmission issues.
One thing I read early on was there was a lot of rapid transmission changes from fwd to rev. It could have been driven by challenging slip negotiations, for me I always pause at neutral then change when I need to hit reverse to stop forward movement. Takes a bit of pre-planning but it is habit now.
At this point and age of these boats, it comes down to maintenance and care give to 310. For example have the coolant hoses been replaced or are they still painted silver from manufacturer?
Overall I think the 310 is in a nice sweet spot, not too old to have poor build quality, new enough to have most standards followed in there construction.
Apr 17, 2021
7
Was there also an issue with the compression post being too short in the first year or two of production? And I thought I read someplace that the early boats didn't have an exhaust elbow heat sheild that was later determined to be necessary.
Aug 29, 2016
138
Catalina 2004 310 (Hull #250) BC
Jan 4, 2006
7,870
Just did the same thing this winter on a 1998 Yanmar. The new AF hoses were all factory formed and worth a fortune.
pk104
Jun 30, 2009
208
Catalina 310 Atwood Lake
My 2001 had burn marks on the bulkhead and rear cushion when we bought in 2007 from the exhaust elbow. It is a Universal diesel. Catalina sent me a heat shield to install that required cutting a hole in the bulkhead and screwing the shield on the backside of bulkhead. It worked.
Previous owner had motored a lot on the east coast. Don't know why he didn’t have serious fire. Sorry I don’t have a picture handy.
Clydo
May 28, 2013
371
Catalina C310 SF Bay/Delta
My 2003 had same thing and same result from Catalina. Easy install on shield.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Clydo
May 28, 2013
371
Clyde ...... I have a 310 2003 also. The pad your using, what is it made of.
Like top of shoe box lid lined with foil made out of wood. Call Catalina factory
and ask for Warren in customer relations. He is very helpful.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
john2
Nov 26, 2022
103
Catalina 310 58 Leimuiden
Does anyone has photo's of the modification / heat shield?
Thanks , john
