Upon starting when cold, our overheat buzzer or the sensor is buzzing constantly with the switch on. It continues to buzz as the engine heats up. I am having trouble figuring out which is the temp sensor to disconnect to stop this. I am about to do a 4 hour run and do not want to listen to this the entire time.
I tried disconnecting the sensor at the front of the engine near the thermostat. That does not shut it down. Any thoughts?
