Speed/temp sensor wire splice
Jul 23, 2009
931
After wasting 3 hours trying pull out the factory installed Raymarine speed/temperature cable, so I could install a new sensor, I gave up. I purchased an approved water proof splice kit instead.
You will need a tiny 1.3mm Allen wrench. I did not have one on the boat, another project delayed.
Here are a few pictures. I should have stripped back almost twice as much of the outer jacket. It's tedious working with such small wires.
1,630
Hunter e33 Maple Bay, BC
Thoroughly check the packaging the splice kit packaging. Mine came with the correct allen key.
By the way I installed it 5 years ago and have not had any issues to date.
Mar 31, 2023
17
C&C 33 Mk 1 Portland
Can you please give me a link to this? Someone cut the data cable to my unit on the new boat.
Jan 7, 2011
6,014
Oday 322 East Chicago, IN
How much did it cost?
Other than the “water-proof” housing, is there any reason you couldn’t just connect the wires with wire connectors?
May 7, 2012
1,630
Once I realized that the Allen key that came with the kit was an odd size, I ordered a bunch to have on hand for when I did lose the original.
May 7, 2012
1,630
No reason at all, except in most cases including mine the transducer cable is run through the bilge. When I occasionally remove the transducer to clean it, I am glad I spliced the cable using an IP67 waterproof housing. I suppose heat shrink butt connectors if done properly would accomplish the same thing; however, that was recommended not to be used by the Imarineusa support desk. I took that at face value and didn’t get into “Why not?”
capta
Jun 4, 2009
5,113
After splicing the wires together and heat shrinking the connection, you might want to cover the whole thing in a layer of tin foil, to help keep out (or in) any spurious radiation, and cover that with heat shrink, too.
