Hello, I have just acquired Jolly Rodger a 1984 Cherubini Hunter 37 cutter and have read the threads concerning holding tank leakage. I am wondering what percentage of the volume underneath the shower seat is taken up by the original holding tank. My thought is to build a tank with Plywood And fiberglass epoxy to use the entire volume of the area underneath the seat. I have done a good bit of glass work and epoxy fiberglass is a very low permeable thing even though plywood not so much. Fiberglass would be on both sides of the plywood tank. Any guesses as to the total volume underneath the seat if I were to cut the entire top section off such that I could lower the tank into position? Thank you very much. The boat was purchased while on the hard and I'm looking forward to getting her back in the water! Regards, Terry
