410 Owners with Y-Valves for aft head?
Jan 12, 2016
273
Hunter 410 Ladysmith, BC
Does anyone have a Hunter 410 with the aft-head plumbed with a Y-valve? Ours wasn't fitted with one, and I'm considering adding it for the aft head. Where is the through hull for the direct discharge located? Any pictures would be greatly appreciated. I've looked at the manual but want to be sure before doing any cutting that the placement is proper.
JamesG161
Feb 14, 2014
8,086
Hunter 430 Waveland, MS
Our H430 Aft hold tank.
No "Y" valve.
A PVC Lateral is used.
Why?
Shared with Deck pump out port.
Jim...
Jan 12, 2016
273
Thanks Jim,
My thinking is having a direct pump out option (head to Y-valve then overboard or holding tank) while maintaining the ability to use the holding tank. In the event of a failed macerator, I can still use the head with a full tank.
Aug 18, 2018
166
Hunter 410 MDR
I have a y valve on both heads to direct discharge, both are original to the boat but it also came with vacu flush systems.
It's in the aft port lazzertte where the vacuum pump/tank are located.
My boat is a 99 410.
Likes: VanIslandGuy
Dec 25, 2000
6,059
Hunter designed our 1991 sanitation system that has worked well over the years. Simple and cost effective. No need for a wye valve. However, we do have a wye fitting that serves as an inert tank discharge choice between deck pump out or macerator overboard, but to both. A single hose from the tank discharge standpipe connects to the wye fitting. Depending on which discharge hose is used, either will empty the tank.
Likes: VanIslandGuy
