Proper prop size tartan 33
Jan 12, 2023
6
Tartan 33 charleston sc
have tentatively agreed toto buy a 1980 Tartan 33... had the bottom cleaned and was advised there was no zinc on the prop shaft and the prop was in poor condition. I thought would know prop size but he does not. It has the 25 hp universal diesel engine... anyone have info on he prop size for this boat.
Dave Groshong
SBO Staff
Staff member
Jan 25, 2007
1,867
Catalina 22 Seattle
Most prop shops will ask the waterline length, max RPM's, max speed, transmission reduction ratio and engine brand/model
capta
Jun 4, 2009
5,008
Most prop manufacturers have a prop sizing guide on their web site. You will need some information, including the gear ratio of the transmission, which is very important. You may also be looking at replacing the shaft if it has been zinc-less for some time, so be prepared for a fairly large hit there.
The old prop should have its info punched into the hub and you could begin there, however, there is no guarantee that the former owner installed the correct prop, so be careful.
Likes: Tally Ho
I did find this... Prop Calculator
Interesting calculator. I tried it with the numbers for my boat and it suggested 16x13 for 3 blades. Our fixed 3 blade prop from the factory was 17x12, and we’ve replaced it with a Flex-o-fold 16x12. Both of those behaved very well, easily reaching hull speed and being able to get maximum RPMs just below full fuel. So I’d say the calculator can get you close but might not be perfect depending on the exact prop model.
Dave’s list
  • waterline length,
  • max RPM's,
  • max speed,
  • transmission reduction ratio
  • and engine brand/model
is a a good start.
I like the information I found on the site WestbyNorth.
It helped to better understand the issues associated with prop selection.
I inherited this prop on the boat
Working with a prop shop I installed this
Great improvement in engine performance and thrust. (1.5knots). Also a .9knot improvement in sailing
Seek out an expert over a catalog. I give high praise to WestbyNorth and their CampbellSailor prop design.
Jan 12, 2023
6
Interesting... the top prop looks more like what you'd see on a correct craft instead of a sailboat... what's the numbers for them... diameter and pitch?
  • Ha
I do not know the pitch. I can check the diameter. It is stored in my garage. I was thing of using it as a dinghy anchor.
