In my typical fashion, I plowed forward with a modification without knowing where I'm going entirely. I've always hated the engine control panel pod at the base of the pedestal because a) it's a lousy location; b) combined with the autopilot, the wheel is pushed out so far that the keeper knob barely has a couple of threads to catch, and it DOES come off if you don't constantly watch it; and, c) the rim of the pod has been butchered to accommodate the autopilot lever and it is really ugly and a negative feature on the boat.
Here is a portion of it with the panel removed but the rim is still attached. I removed the panel to see what is inside (as if I didn't know
) and to find out what it would take to remove the rim.
Here's a view with the rim off. I'd love to simply replace the entire pod with something that goes in the same place but is a better fit, but that doesn't seem possible. I think nobody makes anything suitable. I know Catalina Direct sells the panels with instruments (I thought they sold blank panels without instruments - but I could not find the Yanmar replacement, so I'm guessing they are out of stock, probably never to be replaced). My poorly formulated plan is to replace the rim with a low-profile face board made from starboard or painted plywood and simply fit the original panel to it. With a low profile, there won't be much protection for the instruments, but if I can reduce an inch, I should be golden.
Here's a head-on view.
Anybody have any good ideas? Photos below show the rim and you can see how deep the profile is and how bad it looks. Also shown is the panel. The panel is ok and I think I'll just keep it. My biggest constraint, I think, is that the wiring comes from the pedestal and a project to relocate an instrument panel is too daunting.
