Hello everyone,
I have posted on these forum a couple of times. I am a very new sailboat owner and I am trying to learn as much as I can, so please forgive any ignorance about this topic I have. I'm seeking some advice regarding the cast iron keel of my 1984 Hunter 31 Sailboat. I noticed some rust accumulating on the keel during the off-season, and I'm wondering if it's something that needs to be serviced before placing the boat back in the water.
I've attached some pictures of the rust for your reference. As you can see, there are some areas where the rust has built up quite a bit. The rest of the keel seems to be in good condition, but I'm not sure if the rust is indicative of a bigger problem that needs to be addressed. For full context, last summer I stripped the entire keel down to the cast iron and removed all the rust I could find. I covered the keel in antitrust (then cleaned it off based on the instructions I was provided by the product I used) and I sealed the entire keel in a thick layer of epoxy.
If this is something I have to address again, I am not in a marina where I can do the work myself, I would have to move the boat to another yard first. I would appreciate any insights or recommendations you may have on how to proceed. Should I sand down the rust and repaint the keel, or is it something that can be left as is? I'm also curious to know if anyone has experienced similar issues with their sailboat keels and how they addressed them.
Thank you in advance for your help. I look forward to hearing your thoughts.
