Question.... How cold are you all able to keep your top loading freezer in the tropics? My "freezer" can't get colder than 20°F which essentially doesn't keep anything frozen if the compressor shuts off at night (entirely another issue that I'm still trying to figure out). System was inspected and charged here in Tahiti and we were able to get the evaporator plate to frost on all 4 sides of the upper portion of the box.
As for the Secop BD50F, it keeps shutting down due to low voltage error when there's no solar/wind/generator on. I switched the wiring to the fridge wire run with the same results. Fridge with the BD35F runs appropriately on both wire runs. The freezer wire run is 6mm or 10 gauge and about 25' in length. Pulling about 5-6 amps when running. Any ideas on what is causing the low voltage error on the BD50F and not the BD35F? I would have guessed that when the freezer hits the low voltage mark, so would the fridge and it would turn off too, but it doesn't.
