Floor board replacement on a hunter 306
Oct 14, 2017
101
HUnter 306 Aruba
I need to replace the floorboards in our hunter 306 and l am looking into the flex teak options vs the board currently in place.
Anyone have any insights in the matter? Where can you get the existing floorboards?
Saludos from Aruba.
Capt Brinky
RoyS
Jun 3, 2012
1,742
Are you talking about a PVC glue down product? If so, is this to go in the cabin or on the deck?
Oct 14, 2017
101
HUnter 306 Aruba
interior. they are a bit dated and want to spruce it up. My preference is replacing the floor with the same wood. alternative is the glue on soft teak on top of the old boards.
Oct 14, 2017
101
HUnter 306 Aruba
our floor has two layers, first is marine plywood on top of which we have the teak like floor boards.
RoyS
Jun 3, 2012
1,742
If you decide to go with the PVC glue down product, try PlasDECK. Their system requires you to make a template of your floor and send it to them. They scan it and then make a PVC floor that is an exact match to your template. Comes in one piece with borders that you specify. They roll that up, provide the glue and tools, and ship it to you. You apply the glue (urethane caulking) with a notched trowel and roll it down. You can get samples from them with their catalog. They also have an interior only floor covering called PlasTEAK but that is not as rugged as the deck product. I used the PlasDECK in my cabin. Please excuse my photos, the dog tracked in a lot of dirt that day. Nice people to work with. They are in Ohio.
Oct 14, 2017
101
HUnter 306 Aruba
Dave thanks for the info and yes we will use the existing as a template. Roy that looks nice. Did you make the cut outs to the bilge or was that part of the template?
RoyS
Jun 3, 2012
1,742
The original floor in my boat was a 1/4" +/- plywood with a veneer of teak and holly and lots of water damage near the companionway. That had to be ripped out in pieces. Originally there was an ugly aluminum extrusion surrounding the bilge covers. The PlasDECK people suggested eliminating the extrusion and instead they would cut out the bilge cover opening with an 1/8" end mill. All of the edge cuts were made by their CNC machine from a plot of my template. I installed appropriate, hidden edge shims to hold the plywood bilge covers from movement. The PlasDECK factory bilge cover perimeter cut is perfectly uniform and nearly invisible.
Likes: Brinky63
Oct 16, 2021
2
Hunter 31 San Diego
The Deck in the cabin is meant to support weight.
Not on my boat
Jim...
My 1984 Hunter 31
Not on my boat
Jim...
The time has finally come for me to replace a water damaged floor board. The marine carpenter is telling me to remove the old section and bring it to his shop (in tact) and he will fabricate and varnish to match. I'm planning to start the project this week. My fears is that the old board will not come up in-tack.Based on you picture the old board is simple to remove. Any advise before I attempt to remove a 4 decade old floor board??
Mar 27, 2021
177
Hunter 306 Lake Pepin
Hi Brinky. Have you already removed your panels? I’ve got a terrible squeak on my 306 in front of the head that’s rubbing on the floor tray that I’m hoping to address by pulling up the offending panel and sanding it down. I don’t recall seeing any obvious screws or anything but it feels pretty solidly attached. Are there any tricks to pulling it up? Or will I just need to go to town on it and pry it up?
Oct 14, 2017
101
HUnter 306 Aruba
J I had the same problem. I removed all floor boards and support boards below it and placed a support in the corner to hold the weight. Removing them was pretty easy. The former owner had already cut sections in the lower boards. Suggest you do the same if it was not done so already.
Likes: jdrutten
