Head Liner Replacement
May 22, 2022
11
Hunter 38 Long Pond, Conception Bay
I am replacing 2 sections of the head liner in the double aft berth in my 2005 Hunter 38. What I wish to know is can I attach the new head liner on the existing tracks or do I have to replace them? Any advice on the process involved in removing the existing liner and attaching the new would be appreciated.
Cheers,
Larry,
Baleka
Nov 28, 2016
104
Hunter 36 Northeast, MD
tracks can be re-used I have found. Best tool to install is a semi-rigid scraper with the corners ground down into a smooth curve. Stretch the fabric and push it into the channel
Jun 1, 2009
1,881
Hunter 49 toronto
Cheers,
Larry,
Baleka
Ok,
Not a small job.
You will need to template the area, and then cut out the material with about a 1” border for laying into the track.
It’s possible to use the existing material for a template, but it will have stretched, etc.
I found that putting a fine bead of Teflon grease in the track makes pushing in the material way easier
Also, with the tool, use a plastic mallet to slightly tap on the back end. This tends to pop the track open, and is much easier than trying to just shove the material in
good luck !!!!
May 22, 2022
11
Thanks for the advice.
May 22, 2022
11
Ok,
Not a small job.
good luck !!!!
Thanks. Is there a special tool?
kbgunn
Sep 19, 2017
231
2005 Hunter 33 Lake Lewisville, TX
The headliner material is a vinyl fabric with a very thin foam backing. The brand Hunter used is called Whisper Wall. If you search Youtube for "Hunter Whisper Headliner" you'll see several videos for removing and installing the fabric in the holding track. The vinyl is held in place wit a friction fit in the track.
This video shows good technique for installing. Use a putty knife with rounded off corners. A rolling motion with the knife will coax the fabric into the track. Unfortunately the lighting is bad. Link to video
This guy does a rather extensive replacement which is probably more than you want to do. But gives you an idea of how the fabric is installed. Good reference even if you are just replacing one fabric panel. Link to video
Nov 23, 2015
17
Hunter 33 Coconut Grove
Cheers,
Larry,
Baleka
I replaced all the aging headliner in our 2005 Hunter 33. It‘s a big job, but doable. I bought French Vanilla Marine Vinyl on sale from JoAnn Fabrics (look online for 50% off coupons) and used wall upholstery tools. A rounded off putty knife will work as well. There is a plastic track with a groove in the center, screwed into the wall. To access this, lift the fabric by gently pushing up at a corner until the fabric pulls out of the track. If it is in good shape, you will be able to re-insert. All our fabric was too aged. Replacing is a two part process. The track is in pieces, generally screwed into pieces of starboard, or into wood. If the track is an edge, it has the appearance of piping, with a small fold and then the large main fabric , both of which are actually tucked into the same groove in the plastic track. If it is an area where one piece of fabric abuts another, then both pieced of fabric will tuck into the same track groove.
For all headliner at the edges, there is a strip of fabric running under the plastic track, and it tucks up into the track. That small strip covers the outside edge of the plastic track and gives the edge of the headliner an appearance like piping. It will cover the outer edge of the plastic track. The larger main fabric piece will tuck into the same opening in the track from the other direction. Put Teflon grease as others have mentioned into the track. This will not damage the vinyl. We also used food-grade silicone spray on the top of the vinyl (use for any squeaky fabric) to help ease it in. So after the large fabric piece is removed, the track must be removed (I numbered them all) , the old piping strip is pulled out. Place a new strip (about 2 inches wide, place good side down, under the track. In this photo, the track is removed, and the piping fabric is being placed
In the photo below it, you see the old piping fabric in place under the track before the track is removed to replace that fabric. I numbered each piece of track I took off and numbered the corresponding area where it screws back in.
place
The piping strip should be secured well behind the track, with screws or glue. It hangs down about an inch below the track. This is the fabric you will tuck up into the track once you’ve screwed the track back on.
Now you have the “piping” done. One side of the track is now covered with fabric. You will then insert the large fabric piece. Tuck this in to the lubricated track groove.
I used all removed pieces of fabric, the “piping“ edges and the large sections, as templates for the new fabric.
Hope this helps and good luck!
Likes: Dan_Y
Jun 1, 2009
1,881
Hunter 49 toronto
placeView attachment 212787View attachment 212788
Fabulous writeup !!!
Hats off to you
Yes…..definitely silicone grease in the track.,makes the job 90% less stressful
