Cleat backing plates?
May 23, 2016
1,024
Catalina 22 #12502 BSC
Been away from the forum for awhile....that said, wth was Catalina thinking putting cleats on a C22 without backing plates?
Common or do I have a 1 off, as one ripped out during a recent blow....1984 model....thoughts?
AaronD
Aug 10, 2014
735
Catalina 22 9874 Newberg, OR / Olympia, WA
Sorry to hear that. My 1981 didn't have backing plates either. Now she has big chunks of G10 on all cleats (and an even bigger chunk in the bow). Hope you can remedy yours with less effort than my bow rebuild. If it's helpful, Jamestown sells a 6-pack of 12x12 1/4" G10 sheets for a reasonable price. 6 lasted me quite a few years, and I just bought my second pack.
Sep 24, 2018
3,392
Catalina 30 MKIII Chicago
I use Square Unistrut washers. They're cheap, heavy corrosion coating, very thick and they'll outlast any freshwater boat.
Jul 13, 2015
931
Catalina 22 #2552 2252 Kennewick, WA
common -- although they may have considered this appropriate at the time (weak sauce)
Sep 8, 2022
52
Catalina 22 Green Bay
And yet another thing to look at and possibly update. One of these days boat has to start going back together.
May 23, 2016
1,024
well, good feedback guys, I should have specified, fortunately it is an aft cleat (accessable) and fairly eze to replace those.
The foredeck/bow is still solid so I'm not going down that rabbit hole to replace those!
I may, however put a single additional larger cleat centered in the bow, just far enough aft to access from below....any thoughts on that idea, I see others at the club who have done that on various boats....
Jul 13, 2015
931
Similar construct without nearly as much pain to add backing aft-- I replaced the primaries with Harken and gave them a plate while I was there. All my stock mounting points now beefed up-- and I replaced stock Nylon (or whatever material) horn cleats with Schaeffer aluminum all around. Not sure I'm a fan of the obstruction a horn cleat would add to the bow center-- not much space up there as it is and would at least for me get in the way of my jib bag and my Jib hoist and douse routine. And quite honestly working in the hole is working in the hole-- not sure that saves you any real grief vs. re-backing the existing.
File_008 (1).jpeg File_006 (1).jpeg IMG_0299.JPG IMG_0296.JPG Capture.JPG IMG_2388.jpg
Oct 31, 2022
71
Catalina Capri 22 Huntington
After seeing this post I went and looked at my 2022 Capri expecting to see backing plates under all of the hardware. Surely by now they are putting backing plates under at least the cleats, winches and stanchions. Unfortunately no.. Is it that the fiberglass/core on the newer boats much better then the old days where Catalina sees no need to put backing plates under anything or is it just them saving some time/money? I think I will go about putting some kind backing plates on these items just because it won’t hurt and I like projects.
May 23, 2016
1,024
Agree, I don't get it either. Perhaps Cat sees these boats as casual trailer sailors, not tied up long term....still no excuse for no backing plates. We keep ours in a slip year round so it is subject to significant wind tides (no moon tide here), but we can lose 3' of water in a day so lines need to be adjusted accordingly, if not, significant stress on cleats which is what happened in my case....you like projects, you are definitely in the right forum!!!
(Gene, good point on the toes, bag & butt, agree, likely won't do anything to the bow for now!)
Likes: Sail22Capri22
May 23, 2016
1,024
Guys, so the fix seems to be G10 from Jamestown, thinking below and above glassed in....what do you cut/route G10 with, just thinking top to ease the edges of a "plate" under the cleat.....(have all the "normal" tools, router table, etc.)….any technical advise? And after the repair, paint color to reasonably match above....?
AaronD
Aug 10, 2014
735
I hadn't thought about G10 above as well. Interesting thought - report back and post pictures as you go! Also, I think you'll want to paint it if used above deck. IIUC, it's an epoxy product and UV will weaken it over time.
G10 goes through tools in a hurry. I found carbide-grit jigsaw blades to be a real revelation. I haven't exactly quantified how many inches of cut I get per blade, but they seem to last way longer than anything else I've tried.
If I ever get the DC motor installed on my bandsaw (so I can slow down the blade) maybe I'll get a carbide or diamond-grit band for it and report back. But that's a low-priority project - don't hold your breath :)
After a rough cut with a jigsaw, I usually clean up and bevel the edges on the belt sander.
I should note that, as @thinwater has often said, G10 is usually overkill unless you're tapping threads. Structural FRP board is strong enough and can be cheaper if you're using a lot. But McMaster's price on structural FRP is about the same as Jamestown's on G10. So I just stock 1/4" G10 and use it everywhere.
Hope that's helpful.
Sep 30, 2013
3,594
I finished typing out something I thought would be helpful and informative, and then realized @AaronD had already said everything I was gonna say, almost verbatim. :biggrin:
Likes: rpludwig
