I'm getting a new CB fabricated for a 17' sailboat, so wanted to be sure I understood how it works first. The current CB is in the image. The bow would be to the left. If you look on the lower right corner, it has a pull handle for lifting, with several holes for a cotter pin, which rests atop the trunk and across the slot. My question is... how does it 'stay down' when under sail? I've only ever sailed daggerboard and keel boats. Is it just the weight that will keep it from riding up into the trunk, or just generally being loose? There is no 'pull it down' mechanism.
Thank you!
Thank you!
