Just purchased a 2003 Hunter 326 and I noticed at about 1800 RPM there is alot of banging and vibrating. Upon further investigation I uncoupled the prop shaft from the transmission and it is significantly out of alignment. So - it has been recommended that I replace the motor mounts and while I'm at it i should replace the stuffing box log, the cutlass bearing and possibly the shaft!! Yikes!
I'm all about doing things right but I don't care to waste money and time on un-necessary items.
Seeing if anyone has any recommendations - starting with the mounts - OEM or aftermarket and how do I know they are bad!
Thanks!
Thanks!
