My VHF cable has succumbed to UV abuse. Can anyone recommend decent and reasonably priced cabling and solder connectors?
www.hamradioschool.com
The ironic thing is that loom will break down in UV, at least most of them. I'll most likely use some heavy black heat shrink or amalgamating electrical tape to protect the new cabling. I found a very reasonably priced company that has some potential cables and parts. They reply pretty quickly to emails as wellUV damage? Can you cover the exposed portions of your replacement cable with a sleeve or wrap such as this to minimize further damage?
or
1/4 Inch Black Flexible Split Loom - 10 Foot
Bundle and organize cables easily with our 10 Foot 1/4 Inch Black Flexible Split Looms.www.securecableties.com
I’ve been a ham for decades and have had multiple coax fed antennas including here in the uV capitol of the U.S., Florida, and never, ever has UV caused any problem. Cheap coax is a different animal.The ironic thing is that loom will break down in UV, at least most of them. I'll most likely use some heavy black heat shrink or amalgamating electrical tape to protect the new cabling. I found a very reasonably priced company that has some potential cables and parts. They reply pretty quickly to emails as well
Exactly what happened with a friend's previous boat ages ago. Signal was crap compared to other boats in the marina. When working on new standing rigging the sheathing was noticed to be cracked. New cable and suddenly the signal was great.The dialectic in the cable, the braid, and the core wire also deteriorate due to moisture entering the cable and time. This deterioration affects signal strength, reducing the range and clarity of reception and transmission.
The cable must have 50 ohm impedance. The listing does not specify the impedance. I would not buy this. If the impedance is incorrect the radio will not transmit as designed.The seller recommended this assembly. The price is great but it doesn't look terribly durable. Feel free to correct me if I'm wrong. Seeking opinions on this cable
RFC240 UHF Female Bulkhead to PL259
Bear in mind we are rarely more than four miles from the shore in Chicago. We have a handheld VHF and cell phones so this radio isn't a true necessity (perhaps I'll eat my words in a few years)
That’s precisely the kind of crap I mentioned earlier to avoid - no-name coax and cheap connectors.The seller recommended this assembly. The price is great but it doesn't look terribly durable. Feel free to correct me if I'm wrong. Seeking opinions on this cable
It's deck stepped. I was planning on using a cable gland and soldering one or both connectorsThe cable must have 50 ohm impedance. The listing does not specify the impedance. I would not buy this. If the impedance is incorrect the radio will not transmit as designed.
Is the mast keel stepped? If not, how would you get the connector through the deck?
I've been soldering since I was a kid. I've done everything from other types of coax to SMD. The 259 doesn't look difficultThat kind of gland is for a bare wire, the connector has to be attached after the wire is fed through.
Have you ever soldered a PL259 connector?
