- Oct 22, 2014
- 23,263
There is a lot of buildup in there with the broken zinc that you will want to remove. over time the tubes will plug and cause overheating. I have needed to remove my 3" HX twice in 25 years to completely clean the innards. Once I had a radiator shop do it for $80. The next time he wanted to charge $180 minimum plus. I did it myself.My zinc broke off this year. I removed the center bolt as you did and the cover should be free. Paint probably holding it. You can see the rubber gasket in your third pic. Yes, you can remove the broken zinc from the end. The drill will be needed to get the threaded stub out of the plug (your pic #1) or just buy a new plug with the zinc. I use Boatzincs.com and buy 3-4 years supply at one order- saves on shipping.
Ill definitely start with those. There is no way it slides out without taking out that top wire thing or fuel pump and filer on bottom. I might be overthinking this but I've always found it useful to get some input before starting than after i screw up. this would be a good time for fuel filter change anyways but it's starting to snowball.What happens when you undo the hoses and loosen the two bolts circled?View attachment 212186
Wow 180, yeah since I can't look into the tube from right I'm taking it off. Engine has 650 hours but it's a 99 so who knows what's going on in there. Ill post pricing if i take it to pressure test.There is a lot of buildup in there with the broken zinc that you will want to remove. over time the tubes will plug and cause overheating. I have needed to remove my 3" HX twice in 25 years to completely clean the innards. Once I had a radiator shop do it for $80. The next time he wanted to charge $180 minimum plus. I did it myself.
Welcome to the wonderful world of Boat Project Repair creep.but it's starting to snowball.
I was shocked as well. That was why I did it myself. Those two clamps that John circled are what hold it in place. My Universal M-25XP is a bit different so I cannot answer directly. I would loosen the clamps, remove the hoses and then see if it can be removed by sliding the HX sideways one way or the other. You can rotate it to get the fittings on the end to miss stuff and pass through the opening in the clamps.Wow 180, yeah since I can't look into the tube from right I'm taking it off. Engine has 650 hours but it's a 99 so who knows what's going on in there. Ill post pricing if i take it to pressure test.
Yup it's a new to us and this has been on hold for a while though I'm hoping to get to it soon. I suspected as much and one of the bolts is seen on left but the other us under the fuel pump so a bit more tricky to get to. Ill report back in when I've started this.I have a Westerbeake 46 with the HE in just about the same position. The bolts that jssailem circled aren’t the key. There are two other bolts that hold those strap things on to the engine block, which I believe are on the bottom side of the heat exchanger. Once you get those off it’s easy peezy to disconnect the hoses and pull the whole heat exchanger.
this sounds like a new to you boat, if so try and get a the parts manual and technical manual for the engine. You can also go to Westerbeake.com and located your engine. Then they have exploded parts drawings of all the engine systems with part numbers.
also recommended is to descale the cooling system and have theHE cleaned and pressure tested. Mainsail had a great write up on doing this. I made up a little kit and now do this every couple of years when I change coolant.
Doing the same, it's soaking vinegar right now. I opened both ends, I'm pretty sure it's all zinc so next is to open up the ends, i carefully used a brush in there and most holes opened and looking through there are no obstruction.That is what mine looked like. I dipped it in vinegar and that got out some crud but not much. I then tried phosphoric Acid which is the generic name for Barnicle Buster and that cleaned out all of the salt and aquatic deposits. It did not fully clean all of the tubes because I think some of them were plugged up with zinc debris. I then used a 3/16"ø x 12" long drill bit to hand ream out each tube. I did not mount it in a drill just ran it down the tube and gently twisted it with my fingers. That dug out the rest of the junk in there. I then finished up with another round in the phosphoric Acid and then rinsed with lots of water. Then I painted it with zinc chromate primer and an enamel engine paint.
