I have several spots where there is a large spider crack in the gel coats, and I know on small ones to grind out the crack to a "V" and fill it with gel coat or bigger ones with fiberglass. But as you can see in the attached pics is an example of one on my boat and am looking for a manageable way to fix this. The large crack port of the cleat I know will need more I just using this pic as an example of the spider cracks. Also in the long run I would not like to repaint the whole deck right now so that things don't look patch work. So a I am asking the group as many of you have dealt with this and might have found a good way to address it. Thanks for your eyes and knowledge on this.
