Anyone installed a diesel heater (of any brand) on a Catalina 34mkii? I would like to install the exhaust port on the transom, but the swept nature (about 45-60*) will cause even the bent elbow through-hull to catch rain and spray. I can run it out on a vertical area, but any condensate will drip on a step, is this condensate caustic and will it damage gelcoat? Or, once these heaters get going, is there no condensate to speak of because everything just turns to steam and blows away with the exhaust?
Other option for through hull exhaust fitting would be as far aft as possible on the port side, just about the height of the decal. This area seems unlikely to be in the water unless we have bigger problems. Could always install an expanding bung when not in use to seal it for sure(with a note reminding to remove permanently attached to the control of course)
Thanks for any suggestions, the Admiral is looking forward to being warm...
