So,, as noted on another post, I decided to strip out all my really smelly Sani hose.
I ran into a challenging problem, which sorta deserved a new thread.
I ran into this exact same issue when I re-hosed my 40.5 years ago
The problem is replacing the hose which connects to the deck pump out fitting.
The misery of this job, and I do mean “misery, with a capital M”, is that it’s impossible to get at the hose clamps that hold the clamps onto the hose barn on the deck pump out.
They are basically just under the fitting at deck level, And, the hole in the deck that the fitting and hose go through are just big enough for the 1 1/2” hose.
The hose clamp will NO WAY fit into the hole.
The first job is by hook or crook getting the existing clamps off.
2 tricks
Remove the 3 deck screws from rye pump out fitting, and work all the sealant loose. Get it so that the fitting is loose in the hole.
Now, you can cut the hose, about a foot away from the fitting.
This will give you the ability to twist the short length of Sani hose still attached to the clamps and fitting.
With a flashlight, and a spring mounted 8mm socket you can rotate to hose clamp around so that you can very laborious get at one hose clamp at a time, slowly loosening them enough to remove both of them.
so, you can now pull the short stub of hose through the hull. But how do you re-install???
The Hose clamp screw assemblies are too large for the holes.
on My 40.5, I actually cutprofiles into the deck for the clamp screw.
No more….I use a tool called Clamptite
It permits you to make extremely strong hose clamps out of simple stainless wire.
It is super low profile, and will fit right into the hole.
The tool has been on board for many years. It has many purposes; this being an excellent excample
2 tricks
