The latest addition to my boat was this 560 Ah LiFePo4 (Lithium Iron Phosphate ) battery build. It consists of 8 280Ah EVE prismatic cells in a 2P4S configuration. It has a 200A BMS, meaning it can deliver that much from the batteries if needed. This battery takes up the space of 2 group 31 batteries. You can see a group 31 battery beside the grey LiFePo4 box for size comparisons. The group 31 AGM is only used for starting the engine. The lithium battery is thermally monitored by 3 probes to the BMS and is programmed to disconnect if any parameters are exceeded. There is a 250A ANL fuse directly off the positive post followed by the positive buss bar. The great thing about this battery is that it has more usable power than 8 of those group 31 AGMs! For example with a 100Ah AGM, only about 50Ah are usable. You can use 100% of the LiFePo4, but using only 80% will increase its life.
One of the main considerations when installing a LiFePo4 battery is burning up your alternator. I handled this by installing a Victron DC-DC charger between the AGM battery and the LiFePo4 bank. There are other considerations as well, that I won't go into now, but of course safety is the main consideration. I believe that a properly installed LiFePo4 battery system is as safe as any AGM. Last spring we spent about 3 months cruising from NW FL down to the Keys and back and the battery worked flawlessly (we only carried two 170W SunPower solar panels). We ran the built-in fridge along with a portable 12v freezer, microwave, ice-maker, coffee maker, induction cooktop as well as all of the boat's other electronics. We have a 2200W pure sine wave inverter that can be seen in one of the photos.
FYI. The cost to build the battery was about $1500 for the 8 cells and the 200A JBD BMS.
