My 320 is hull #307 and I cannot determine if it is the Westebeke 30B (3cyl) or 29B (4cyl). Anyone know how to tell? And what oil is advised? And...lastly...what max RPM advised for long cruising? Ben
Count the injector lines / injectors. Each cylinder gets one injector.
Once you know which engine you have, get the manual for it. Although, you can probably figure on Shell Rotella 10w 30.
As a general rule, max RPM for extended cruising is going to be 70 to 75 percent of max RPM. Once you know which engine you have you'll be able to get the max RPM and just do the math.
White Lake, huh? Greetings from Muskegon / Catalina 315.
Taking it in the spring from Toledo up and around to WL.White Lake, MI and where will you cruise?
Have someone send you a picture??Thanks...I just got the boat and it is on the hard in Toledo. Prior owners not certain. Catalina put two different engines in that year. I don't have an owners manual so checking the injectors is probably best bet. Thx.
Or count the spark plugs.Count the injector lines / injectors. Each cylinder gets one injector.
Of course....but I am in Grand Rapids 3 hours away. I should have check this out when I was there last month. My bad.Or count the spark plugs.![]()
Don’t waste your time counting the spark plugs…Of course....but I am in Grand Rapids 3 hours away. I should have check this out when I was there last month. My bad.
Understood you're not close to the boat.Of course....but I am in Grand Rapids 3 hours away. I should have check this out when I was there last month. My bad.
