GPS antenna on Hunter 23
Apr 28, 2018
17
Hunter 23 LaCrosse WI
Does anyone have a suggestion on where I can mount a Raymarine Gps antenna on my Hunter 23. Thanks.
They are not line of sight like a VHF ... so you can mount it any place that is convenient. Consider the coax run to the reciever and if any lines etc. will wrap around it. I mounted mine on the mast crutch pole.... I also kept a small solar panel there.
Apr 28, 2018
17
Thanks. The picture helps alot. Is that a vhf antenna on top of the gps antenna?
