OK I need to help! I have a pair of LG395 Fixed Panels connected to a single Victron MPPT Smart 150/60 Controller. From there I have a 60A Breaker to my battery bank of 6 Trojan T105's 6v 3 sets of 2 in parallel. The system worked fine for awhile then started tripping the 60A Breaker when the sun was brightest. I changed the breaker but is continued to do that. I thought maybe the two panels might be to much for the battery bank so I installed a switch to isolate one panel. That worked fine for awhile but then the breaker started tripping again. Now even when the breaker is set it is not charging the battery bank. Question! Is it the panels or Mppt or breaker that is bad. I checked the batteries and they seem good. The MPPT shows a solar panel voltage but no amperage (see picture). I thought it might be a bad breaker so I have one on order. I am leaning towards a bad Controller but wonder about the panels since they got shaken up pretty badly during Ian but the system did work for awhile after but now nothing. I checked the panels for damage they look good but i have no clue how to check the panels for voltage other than thru the controller. Any suggestions?
