Is moisture intrusion the only cause of delamination?
There is one spot in the cockpit that emits a loud “CRACK” when I step on it. This spot is were everyone Boarding the boat steps, and everyone entering or leaving the cabin also puts a foot here. It is probably the most frequently trodden spot on the whole boat (Macgregor 25).
The observable symptom says “delamination”, and it’s hard to imagine it being anything else. But, close examination shows no means for water to intrude. Is it possible that this delaminated due to repeated flexing stress rather than moisture intrusion? If this is a the case, would a moisture meter be a viable tool for checking?
I ask because the drives what my fix will be. If the core is dry and intact, I’d like to drill, very carefully, from belowdecks through the plywood core, stopping just as the drill bit touches the cockpit floor’s fiberglass layer. I can inject epoxy from back here without compromising an apparently good cockpit floor (see attached sketch).
